johnny
AndyT":rb4r5icz said:As Lurker said, you could just copy the joints used in the box in the picture - which are simple rebates. You could cut these by hand, or with an electric router. If you work carefully and use decent ply, they are not very hard to do. You can glue with PVA and use fine panel pins to hold the corners together. A lot of extra strength will come from the bottoms of the box / trays, which can be cut slightly oversized, glued and pinned, then planed back to the exact size.
The rebates make consistent alignment easier but on a small scale are not essential for strength. See https://www.ukworkshop.co.uk/forums/post974412.html#p974412 for one I knocked up.
thanks for the link Andy.
As you say the addition of a base glued and pinned adds considerable strength to the construction and doesn't need to be very thick either. i constructed 2x campervan bed/seat bases from 25x18mm frame with 3mm ply sheet glued and screwed it takes my weight easily which is nearly 18 stone . https://youtu.be/w48QqVXiTEw
