Hi all,
I'm designing a walk in wardrobe which will look something like this:
As you can see, there's some shelving units starting about 2m high. I had originally designed these to be built as separate carcasses from the 'base' units. But I've just found out that I can get my walnut veneered mdf boards in 10' (3050mm) heights, which is more than enough to create each unit as a single full height piece. I.e. three parts each about 2600mm high, rather than three 2100mm high units and three 500mm shelving units on top.
It's my house, and I'm cutting and fitting on site. The room height is 2.85m, so enough headroom to be able to assemble the units lying down and then stand them up with clearance even when taking account of the diagonal from bottom back edge to front top edge.
Building them as three units rather than 6 saves a bit on materials (cost and weight), and also neatens my design a tiny bit.
Is there any reason why I should build as six carcasses rather than three?
