A
Anonymous
Guest
You must enter a message when posting
Mr_Grimsdale":13rma6do said:Yes sorry - sweeping statements always have many exceptions. Of course you should mark pins from tails. But you shouldn't then mark tails from those pins (if you felt so inclined). That's where the error accumulates.
The 'rod' principle is that you are always referring back to base.
Mr_Grimsdale":1a5u0rlk said:I'd like to see that. Rods are a particular enthusiasm with me - as possibly the single most important thing every woodworker should understand. Email?Sgian Dubh":1a5u0rlk said:Roger, if you can't locate the back issues, I do of course, still have the original text including images on my hard drive all in Word format. Slainte.
cheers
Jacob
OK, call me perverse, but some of my rods contain details of differences between layouts on the same type of structure and I feel that they are clearer by having the differences highlighted in a different colour. For example I have a rod made for 722mm high kitchen base carcasses which holds the drilling centre lines for highline, drawerline and multi-drawer (2-, 3-, 4- and 5- drawer) cabinets. The only extra colour I normally is red a two colour rod suffices to differentiare between the carcass types. The reason for keeping it all on one rod is simply one of cenvenience. It's probably just a matter of what you get used toMr_Grimsdale":7bdd6kz0 said:Coloured pencils might help but when you get used to it you find you can 'read' a rod and recognise what everything represents. Also the marks on the components can be read like a bar code - you soon get to know what each line, or particular group of lines, means
Sgian Dubh":1lavoheu said:Those of you that have contacted me ------I should have sent you a copy of the article under discussion.
