frugal
wizer":12uk9zyt said:Lovely work. This absolutely stinks of victory =D>
I don't know, Jack55's bedside cabinets look great :wink: . Win or loose I am really proud of this as my first piece of cabinet making.
OPJ":kddaquah said:That's some nice-looking English cherry. You mentioned the problem with woodworm, which is very unfortunate but, did you find some of the boards split quite badly? 1in. boards are not renowned for their stability as the wood dries... :?
frugal":3mtm8mbj said:EdSutton":3mtm8mbj said:I reckon they're pretty good for a first attempt at dovetails. Personally I would make the tails bigger in relation to the pins, but the layout of dovetails is a matter of personal preference so theres no right or wrong.
Ed
Ed, The base of the pins was as small as the width of the smallest chisel I have available to clean them out. I have never figured out how people clean out the waster between the tails when the pins taper to just a saw kerf thickness.
EdSutton":c4skz8r9 said:frugal":c4skz8r9 said:EdSutton":c4skz8r9 said:I reckon they're pretty good for a first attempt at dovetails. Personally I would make the tails bigger in relation to the pins, but the layout of dovetails is a matter of personal preference so theres no right or wrong.
Ed
Working to chisel size is good practise, but you have the sizing of the pins and the tails the wrong way round I think - the tail should be the bigger bit and the pin the small bit. If you worked to the smallest chisel you have for the baseline cut between the tails (i.e the bottom of the pin) that would look right.
Not meaning to criticise, just trying to clarify what I meant.
Ed
frugal":1awkmqb0 said:EdSutton":1awkmqb0 said:frugal":1awkmqb0 said:EdSutton":1awkmqb0 said:I reckon they're pretty good for a first attempt at dovetails. Personally I would make the tails bigger in relation to the pins, but the layout of dovetails is a matter of personal preference so theres no right or wrong.
Ed
Ed
Oh... oh dear... bugger!...
Well, I did say that it was the first time I had cut dovetails
