Roger
Now Jacob - are you just trying to cover all languages, reference sources and phraseology ? :wink:cleaty wotsits if dry etc. in fact better as the breadboardy thingies
One aspect that may, or may not, be relevant is a kitchen table will get crumbs, crud etc on it in the normal course of use - will a breadboard end/cleat/doohickey/whateveryouwanttocallit not provide an extra place for such crud to be lodged? Just a thought.
wrightclan":1gbwmw5a said:This academic paper...
http://cfaonline.asu.edu/haefer/classes/564/564.papers/pierceharpsichord.html
...mentions the use of breadboard end construction in the casework of an 18th century harpsichord. I don't have any idea when the first use of the term breadboard end was used in this context; but it's certainly not an invention of modern mags. As I understand it, the term does derive from its use in breadboards for bread; but it is a traditional technique (with both inherent advantages and inherent difficulties as disputed on this thread) and it is a traditional term (probably Yankee in derivation.) :wink:
Brad
The fronts of the cheek are finished with breadboard ends. The breadboard ends to the cheek and spine are merely hardwood pieces inlaid 8mm into the outside surfaces.
wrightclan":4lov9nsq said:Shivers,
Everything in your above post misses my point entirely on so many levels. I didn't say that the term was in use in 1769. As I said, I have no idea of the earliest use of the term. (But I can probably find references that go back to at least the early part of the 20th century). If I remember correctly, the makers of the harpsichord in question were Flemish, and wouldn't have used the term "breadboard end" or "cleat."
The author isn't a woodworker (as far as I know) and likely doesn't read woodworking magazines. The author is a musical historian. Why would a musical historian (who likely doesn't read woodworking mags) use a term like "breadboard ends" to describe the construction of a part of a harpsichord(if indeed as you contest, the term is a modern invention by woodworking mags aimed at amateurs)? Perhaps it is because the term has become a part of design lexicon (especially relating to woodwork) to such a degree that the author understands the term and believes her readers will understand the term as well.
Brad
Mr_Grimsdale":2a9vmw3j said:sez ere in my "Joinery and Carpentry" (Corkhill Dowsett Millar Hayward Duckworth Hancock Bennetts) 1929, glossary;
CLEAT. A bearing block nailed under a beam. Also the wooden cramps used for jointing together long lengths. Also alternative name for a small batten.
I only have a problem with mis-use of a word when the user thinks it is the right word in some technical way, rather than it being the users best stab at finding a word which fits.
chers
Jacob
Shivers":19tudt76 said:I was also taught the term in college whilst doing city & guilds --so how wrong can that be.Maybe i should go back & tell my lecturer off.
regards.
Ok calm down,my lecturer was 70 yrs old & had spent 50 years in the trade,how much more of a reference should i use,should i adopt a usa term just because its in a mag,or should i try to instill some brit trade terms.wrightclan":3ei5snsl said:Shivers":3ei5snsl said:I was also taught the term in college whilst doing city & guilds --so how wrong can that be.Maybe i should go back & tell my lecturer off.
regards.
Umm, Exactly at what point did I (or anyone else) slag off your use of the word "cleat." You're the one who has been ranting on about the use of the term "breadboard end," as if it's a totally unacceptable term foisted upon unsuspecting hobbiests by evil woodworking magazines. (Just so your clear, that preceding sentence is a bit of intentional hyperbole.)
Brad
Shivers":gqyksqog said:Ok calm down,my lecturer was 70 yrs old & had spent 50 years in the trade,how much more of a reference should i use,should i adopt a usa term just because its in a mag,or should i try to instill some brit trade terms.
