Colron "Natural" - is this supposed to be clear?
silm
16 Mar 2010
Hi all.
I took the plunge and put the first finish on my oak unit last night. It looks good, but a little (well, much) darker than I expected/hoped.
I used Colron "Natural" - as opposed to Antique Pine, Georgian Medium Oak, etc. - because I was after a finish very close to the colour of the original oak.
Was this a mistake? Is this darkening expected of all Danish oils, or did I just interpret "Natural" incorrectly.
(In my defence, this is described as "Clear" on Focus DIY's website).
I know you have to reapply every so often. Does this mean it will lighten in time? Would a second coat make it even darker and should I just leave it at one?
Thanks in advance,
Steve.
Steve
Yes, the oil will change the colour of the oak - the oil has a yellowing effect. But most people like the look - its quite a natural look.
Once it dries it will lighten a little - the other oils you mentioned have dyes in them to give the colour change.
HTH,
Philly :D
Thanks Philly.
Would you expect the oil itself to be clear or to be (as my Colron "Natural" was) the colour of very diluted Coke? (with a slight reddish tinge).
To clarify, the oil was this:
http://www.screwfix.com/prods/54151/Pai ... Danish-Oil
As I say, currently the colour looks much darker than the original wood. It's been drying for 12 hours so far.
I just wanted to check this was expected.
Thanks for all your advice.
Yes, mine has a reddish tinge too. That's normal for this product.
An oil finish does darken the timber - wet an offcut of timber with water and you'll see a similar colour change.
Philly :D
Thanks. I did wonder about the water/oil analogy.
One final question. Is it likely to get darker if I add more finishes, and (if so) is it okay/common just to leave a single finish?
Many thanks,
Steve.
No, shouldn't get any darker. One coat is acceptable, but you may as well wipe a thin second or third coat on to give a better finish.
Best regards
Philly :D
Next time, try a clear water based lacquer.
