johnnyb said:It may seem slightly pig headed not to stick 1/2 inch on top. But it's a useful exercise in joinery with a nice result.That sounds like a perfectly good reason !
Sent from my SM-G900F using Tapatalk
It'll still be a decent frame with out the smaller tenons Jb. I'm the same with it taking a few reads to properly get the grasp of somethingjohnnyb":2byeduoj said:Rereading coleys post I seem to have missed a few bits. Ie coley makes his tenon's smaller to conceal his gaps( how did I miss this?)
I'm also understanding what you did with the angled cill cut and the pair of compasses!
I think I tend to scan stuff quickly then crack on. On second reading after doing it wrong( differently) I completely understand.
Where I did my apprenticeship 95% of any joinery they made was softwood. Even though the majority was done with machines I'd spend days fitting/scribing door and window moulds. I use to enjoy doing single glazed windows the most with multiple panes. It was always good after cutting & scribing each vertical glazing bar (between the horizontals) then see everything close up tight when it was assembled. I found it a bit of a leap changing over to hardwood but now I find that easier to work with- probably because I'm more familiar with it now.johnnyb":mu3x08ju said:I can imagine making sashes by hand would be nice using this stuff.
Jb
I don't think there's really an ideal glazing rebate for single glazed putty. The bedding in on putty and panel pins alone should prevent the glass falling out. I think you've kind of sussed out the reason already for the dimensions. Ive never seen single glazed casements any thicker than ex 2 inch (44-45mm) but have seen them as thin as 35mm. A half inch tennon fairly centrally spaced allows for a decent strength joint, the rest is just working to that. I guess having putty at a reasonably steep angle helps draw the water away more effeciently.johnnyb":2asfn029 said:I'll run one like you say a nice combination will allow straight shoulders. What is an ideal glazing rebate. I think yours were 7 by 18. I should manage this if I extend to about 12mm. That will be 12.5mortice + 18 rebate=11.5mm mould about 7mm deep. I'll try it out tomorrow. Cheers coley
Jb
