Ian Dalziel
For anyone interested….i will be converting my new milling machine to cnc…..i have about 90% of the bits required…just awaiting a couple of things then I can get going. with advice from Kong
I will be running a project log here
http://www.cnczone.com/forums/
If you would like to see it run here as well, let me know, I’m aware that this is a woodwork forum but it might interest the odd few.
Converting a mill or building a cnc router isn’t cheap……excluding the mill I’ve spent £1680 so far and about another £200 is needed for bits and that’s before I buy software. I have tested sketchup drawings saved as dxf files and they look as if they work so hopefully wont need an expensive package but time will tell.
regards
Ian
regards
Ian
