The gear cutters are Thorntons - I was lucky they came with the Unimat.
It maybe worth considering buying ready cut pinions and wheel blanks from Ian Cobb because I think you need 3 different cutters?
Here's a pic of the overall pinion cutting using a dial gauge on the cross slide to check depth of cut:
Here's a filing rest I made to file the tiny flats on the Minute Hand/Hour Hand Bush:
This is two tubes - one inside the other and when made up gives this train (hands not connected yet)
The two files are in fact scraper/burnisher for polishing the brass.
Good luck
Rod
Good luck
Rod
