• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Clarke SE16C150 compressor - unused
Sporky McGuffin
Light entertainer
22 May 2015
Headley Down
You may be detecting a theme in my for sale threads. I'm clearing out a load of stuff I thought I'd use but never did, in favour of a very few things that I actually will.
This is approx 10 years old and never turned on - it sat unloved in a corner of the last workshop as I realised I'd rather just do brushed and rubbed finishes. The pump wheel turns freely.
Around £600 new, I believe; the sold ones on eBay and the like have been around £300-350. I will suggest £290 £240 including the airbrush (I think from Axminster), mini gun (used with a different compressor before I upgraded) and biggish Yama gun (unused). Also a bit of multicoloured hose. I am open to sensible offers, however as it's the best part of 100kg this is collection only from Headley Down in East Hampshire, and I doubt I can lift more than about 30kg of it. It's in the garage, which is a flat floor to the drive for loading apart from a 4cm lip at the garage door. I can take more photos of any interesting details for any interested parties.
Specs:
14cfm displacment - cast iron, twin cylinder compressor pump
150 litre air receiver (CE certified)
3hp motor, 230v, 1ph continuously rated with overload protection
10bar (150psi) maximum working pressure controlled by a fully automatic pressure switch.
Specification also includes safety valve, pressure gauge, air outlet valve & drain tap.
Dimensions (LxWxH): 1390 x 430 x 850mm
Weight: 97.5kg
    214.4 KB
    211.4 KB
    132.9 KB
    118.9 KB
    99.5 KB
Hi
I am interested in this can you private message me I am a new member so won’t allow me to send private messages
thanks
Beau
