• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Clarke 3 phase converter
topchippyles
8 Oct 2014
gwent
I am selling my 5.5 hp clarke 3 phase converter as i have upgraded to a transwave converter due to bigger machines.I have just had it fully serviced so ready to use.Item is in excellent condition and located on the heads of the valleys in south wales,Please pm if any questions.
Price is £265
Full spec below
A convenient compact power converter - designed to enable 400 / 415V, 3-phase motors & equipment to operate when only 230V mains power is available. It simply converts 1phase input into a 3-phase output.THESE CONVERTERS ARE NOT SUITABLE FOR USE WITH CAR HOISTS, COMPRESSORS & VACUUM PUMPS DUE TO THEIR HIGH START UP LOADS.
Adjustable power output to match the requirements of motors up to a max. of 5.5hp
230V 1-phase input / 400 - 415V 3-phase output
Ammeter to indicate incoming 230V current
Neon switch on unit illuminates when output load is connected
Max input current: 25 Amps - Input current fuse (supply) 32 Amps
Durable, corrosion resistant case with powder coated finish
Dimensions (LWH) 365x255x385mm. Weight approx. 21kg
Technical specification
Max Output 5.5 HP
Overload Protection Fuse Rating Amps 20
Dimensions 365x255x385 mm
Weight 21 kg
Supply Rating 32 Amps
    148.4 KB
