Clarity on Record Power
29 Oct 2024
Wiltshire
I'm preparing to purchase a bandsaw to support my carving business.
After some research, I think I’ve settled on Record Power. A relative of mine owns one that I used a long time ago, and it did the job well.
My questions are:
  1. Why is there such a large price jump between the BS-250 (£299) and the BS-300E (£699), or between the Sabre 250 (£399) and the Sabre 300 (£949)?
  2. Is the Sabre line worth the additional £100/£250?
  3. Are there any other brands or models you’d recommend for roughing out carving outlines and sawing blanks from large stock?
This is my first post on this forum, so apologies if I’ve missed any posting etiquette.
Many thanks!
the 250 range are bench top (small) band-saws
all others are floor-standing band-saws - so a big physical and cost difference
yes the sabre models are worth the extra - built to a much more professional standard.
I have the 250 Sabre and it is a mini professional band-saw - superb - if I had the space for a floor standing machine then I would have the bigger one...
It may be worth using the search function as there are oodles of threads on which bandsaw is best and these may give you some useful information. You won't find a clear cut answer though!
You mention sawing blanks from large stock - what dimensions are you working with?
@Blackswanwood
I have the option to purchase smaller blanks to work with but for me it would be much more economical to purchase larger blocks and cut my own blanks to whichever size I need. I can't imagine I'll be chopping up anything huge, for the sake of brevity I'll say nothing more than 8 inches in width/height, but I can't be absolutely certain.
I'll check out some of the other threads for sure there are a few linked below that seem to have some good info in them.
Thanks for the reply.
Only caveat I would mention, is go bigger than what you need currently.
You can cut small stuff on a big bandsaw, but you can't cut big stuff on a small saw...
I'm really sold on Record to be honest and Sabre seems like the right choice, I'm just a bit thrown off by the big price jump.
I totally agree though... buying more is almost always a better than buying just enough.
Sabre 250 seems like it's pretty much exactly the size I would need, but on the side of safety (and bigger tool = bigger happy) the 350 seems future proof to the tune of the rest of my life.
£400 to £1250 is just such a crazy jump...
It sounds like you've made your mind up and are just looking for some extra rationale and reassurance.
If the Sabre 250 is the right size and does what you want I'd say go for it. If going for the Sabre 350 doesn't break the bank/stop you buying something else you want/need I'd say upgrade to it.
I've seen the BS and Sabre machines side by side at shows and the Sabre definitely feels to be a notch up in quality. My brother has the Sabre 250 and it's a good machine.
I spent ages weighing up what to get and ended up with a Laguna 14BX. It's great for what I need and I've never reflected on whether I'd have been better with any of the others I looked at.
I'd be tempted to give Yandles a call. They may have all three models available for you to look at, and Martock Somerset Isn't a huge distance from Wiltshire. For such an important purchase, I think it would be worth the drive.
