Cladding summerhouse with softwood shiplap
urbantus
15 Sep 2007
Im cladding my new summerhouse with 110 x12 mm softwood tprereated tongue and grooved shiplap
the shiplap has been stored outside for a week during the warm weather and seems quite dry
Do I fit the shiplap tight or leave a small gap in the tongue and groove
As some of the shiplap has cupped already I was going to fix it by means of one screw in the middle of each board
Does this seem ok
When cutting and fixing the shiplap should I treat the bare cut edges
Whats the best detail on the corners
The shiplap is being fixed on vertically fixed treated battens fitted to stirling board panels
The stirling boards are clad with breathable membrane fabric
Do I need to seal off the gaps between the vertical battens
Or just leave them open to ventilate the rear of the shiplap
Along the front edge of the summer house I intend to bolt a new decking joist to the summer house joist so I can erect an external decked area
How do I finish off the shiplap at the junction of shed and decking to avoid problems with rain water
Thx
Urby
Tight, as it will probably shrink some more.
I would use nails, unless you want to dismantle it in the future, use two as this will "flatten" the cupping and allow the next board to fit on.
Yes.
Its usual to fit a vertical board to butt up to front cladding and to cover the end panel cladding.
You can leave it or fill with insulation.
The last cladding board should be at least 1/2" above the decking floor to allow any rain to drip off.
Thx for advice
I might still screw the shiplap as I think Ill have more control that way
If I leave tha gap open at the bottomis there a danger of insect getting in behind the boards
or doesn that really pose a risk
Thx
