AES
Andy are the Pegas badged machines still available over there?
AFAIK, yes. Will be checking soon, but a bit busy on other stuff right now. More asap
Thanks - much appreciated. Moving to variable speed is on my list. My existing machine vibrates extensively and left unbolted will walk off the bench as soon as I look away despite having a few parts replaced / updated. What has confused me to date is it's a single speed Hegner so the comment on the motor seems very relevant (and welcome). It pre-dates the quick tension release - another essential for the future.For cutting delicate fretwork I would recommend variable speed, you can manage with single speed but a variable speed gives you much more control and makes cutting more relaxed.
Vibration is an issue with some models and often worse when the machine uses a universal or brush-type motor rather than an induction motor which apart from running smoother are much more reliable.
My first decent saw was the Diamond which was a very well build British machine but vibration is dreadful, if you placed it on a bench and turned it on it would vibrate all over the place, the only way to 'control' it is to bolt it to a very sturdy bench and bolt the bench to the floor. (My youtube channel has a video on the Diamond)
A few years later I bought a Hegner and what a difference, vibration was minimal and it could be used just placed on a bench. I found it a joy to use and 24 years later I still love the machine. Hegners are expensive but not for one moment have I ever regretted buying the machine. On the downside if you need a spare part the price they charge for them is horrendous and in my view totally over the top. however the machines are very reliable.
My buying advice is
1) Buy a decent make and don't be fooled by some makers who stick their logo on a Cheap far east machine and infer that it is quality.
2) Choose a machine with an induction motor if you possibly can
3) Make sure it is very easy to change blades (awkward blade changing will drive you mad if doing lot's of internal cutting).
4) Make sure it has a quick blade tension device (for the same reason as above)
Buy a quality machine to start with, it will encourage you to keep using it and if you really get fed up you can sell it for a decent sum, whereas a cheap saw that is awkward to use will more likely put you off the hobby for good plus it will be more difficult to sell.
All my personal opinions others will think differently.
I have an old two speed Delta ,it has the quick change blade fitting, wouldn't swap it for a HegnerThank you! I searched eBay for delta but somehow missed this one. I believe this is the 40-540 which is the budget end of delta? Any idea which would be better out of this or the Axi 456? The Axi seems much better spec'd.
Many thanks. I think I found the post you mention but for someone that is a novice and only looking to cut 25mm would slices and the likes of 20mm simple plywood shapes what is the recommended blade to use? I'm very confused when it comes to pinned and painless blades.See the sticky (permanent post) at the top of THIS Scrolling and Scrollsaw section.
Have you looked at my website? I have a whole page devoted to the issue of blades comparing pin end and plain blades. There is also more blade information on the "Fretwork help page". the link is in my signature.Many thanks. I think I found the post you mention but for someone that is a novice and only looking to cut 25mm would slices and the likes of 20mm simple plywood shapes what is the recommended blade to use? I'm very confused when it comes to pinned and painless blades.
Let's also say I want to cut an internal circle into a 25mm wood slice and use to keep the internal circular cut to create a 3 dimension step by raising it from the original slices surface, what blade would be most suitable?
Thanks, will take a look.Have you looked at my website? I have a whole page devoted to the issue of blades comparing pin end and plain blades. There is also more blade information on the "Fretwork help page". the link is in my signature.
I am really enjoying this and have today finished cutting all the gears for the 30 hour clock!
