"relying on the filter blocking up to provide the required filtration efficiency would be considered poor practice. Running a filter with the required efficiency and keeping it clean to maximise flow rate through the system (and thus dust-capturing ability) is a better approach."
This is the nub of what I was trying to articulate earlier, but failed miserably. I have a twin-bag, leaky, HVLP Axi 'blower'. I use it to extract CHIPS from my AGS saw and my Elecktra 260C planer/thicknesser. The bag weave 'separation' between strands is smaller than the average chip, so I find very little dust exfiltration from either tool, and my asthma remains dormant, even in a closed shed.
My Record HPLV 'dustbin' has a much finer filtration 'weave' where this distance is significantly less; that deals effectively with sub-micron router dust; you can tell from the change in motor note when its paper bag is clogged.
If I reversed the usage, the Axi would initially cast loads of dust out, then the bag fabric would 'load up' with dust and the extraction failure Siggy refers to would happen. The Record dalek/dustbin would probably soldier on for a bit, but its capacity for chips is limited, about a third of the twin-bagger's capacicity.
Returning to the quotation from Siggy at the top of this post, if I had a pools (that dates me!) or a Lottery win, I would invest in a H.D. Bosch, self-cleaning beastie in a heartbeat. I've seen what it can do in terms of " Running a filter with the required efficiency and keeping it clean to maximise flow rate "attched to an R.O.S., and it was a revelation. Certainly, i'd back using one for domestic installations where airborne dust is a concern for either health or finishing, (or both!!).
This is just my tuppence worth - 0.85p in Newspeak - and 'your mileage may vary'.
Be safe, breathe easily and deep. Sam
