syntec4
I'm new here, but I think I might have one foot over the edge of the slope already. :wink:
I would like a set of bevel chisels for general work. I have these at the moment http://www.axminster.co.uk/src/2005wk48/recno/4/product-Axminster-Bevel-Edge-Chisel-Set-31355.htm
But I find they loose the edge very quickly when working with hardwood. The handles are not that well made, but they didn't cost much in the first place so I'm not complaining. I could still use them if I need to Chop out a mortice with a Hammer etc.
I also have a block plane http://www.axminster.co.uk/src/2005wk48/recno/1/product-Axminster-No.220-Block-Plane-210964.htm Which I use a lot and works fairly well but requires constant tweaking/sharpening to get the right cut. It appears to suffer from temperature changes as well, the cut will get heavier as it is used more. Is this normal with all planes or would a bronze body help with this? I guess the blade is expanding with me holding it, but the body does not seem to warm up at the same rate, causing a longer blade and deeper cut? My garage does take a while to warm up at this time of year.
Any suggestions for replacements and you're reviews of specific products.
Budget? er well its not unlimited, but I don't want to buy any more for a while. Honest :wink:
Thanks all.
lee.
Thanks all.
lee.
