Chisel slip! Help with repair
Helvetica
4 Apr 2011
Ireland
Took too thick of a bite of this dovetail, should I glue a repair slip on there now, or fit and repair with sawdust & glue later? It’s probably 2mm wide at the end
Judging by my experience with the difficulty of colour matching sawdust/glue repairs I would think best bet would be a slip of the wood glued in the same orientation and dovetail reworked before assembly.
Yep, if you do as Chas suggests and match up the end grain the 'fix' will be invisible - Rob
Same here. When I've ever tried it it sticks out like a small thumb. I've had better results using a 2pack hard filler. That must make me sound like I do alot of bodging [SMILING FACE WITH OPEN MOUTH AND SMILING EYES]
I dropped the other bit in a sea of shavings unfortunately. Thanks I will try the slip now.
With a splice as small as that it can often be better to cut back a larger amount and splice in something bigger.
Why not remove the entire top of the dovetail, 2mm thick and back to the shoulder and then splice another piece on and re fettle. It will have no effect on the strength but look much better. Your only join line will be along the thinnest edge and running in line with the shoulder
It's the tail board, so you've done this first, presumably, and there isn't a mating pin board yet. Why not just re-shape the tails?
Yes I can see this working well. I tried a small splice but the chisel just knocked it out. Many thanks for all the tips guys
