Wend
Apologies for yet another thread on everyone's favourite topic! But I've been trying to master the art of sharpening chisels, and I don't think I've quite got the hang of it yet.
I'm starting off by trying to work on the back of an old 1/2" chisel. I figure that the back ought to be the easiest bit to do, as I don't have to worry about bevel angles or anything. The chisel isn't in great shape, but I figure that shouldn't matter much for just sharpening practice.
So here's what I started with:
Unfortunately that photo's a little blurry, but hopefully you can tell that the scratches nearest the tip are vertical.
So I started on a coarse diamond stone, with horizontal movements, so I could see what was happening. This felt like it went well, with horizontal scratches soon appearing across the whole end:
(in the photo it seems to have more pronounced vertical scratches still, but in person I'm sure that horizontal appeared to be much more dominant).
Then I went on to the fine diamond stone, with vertical movements. Again, this seemed to go fine, with vertical scratches reappearing.
The extra-fine diamond stone is where it started to feel like it went wrong. I went back to horizontal movements, but there was a triangle (bottom left of the photo) where vertical scratches remained:
(in fact, in this photo, the triangle also seems to have horizontal scratches in, but in person it looked like vertical dominated. It depends a bit on how the light catches it, I think).
I kept going on the extra fine, and the triangle gradually shrunk:
And shrunk more:
At this point I thought I would move on to the strop (leather + Chromium Oxide), to see what effect it would have on the part outside of the triangle. However, it appeared to have no visible effect whatsoever:
I thought that I was meant to be left with something with a mirror-like finish, but this very much still has visible scratch marks on it.
So, do these photos give any hints as to where I might be going wrong?
Thanks!
And shrunk more:
Thanks!
