I have a stainless steel chimney hood to fit at home, which I thought would be pretty straightforward. It has come with a paper template for mounting it on the wall but little or no info on ducting the air out. The hood is to be on an internal stud wall and the ducting has to go to the left, as you look at the hood on the wall. I was planning to use flat channel ducting to run along the top of the wall units with a bridging piece around the chimney to hide the duct. Do I simply need to make a cut-out in the side of the chimney for the duct to pass through and if so how? Hacksaw, tin-snips, angle grinder? Anyone fitted one of these? Any advice welcome before I make an expensive botch of it.
