swisstony
I am sure we have all come across this countless times. The item you are building is needed before you can actually build the thing you need. I will post up pictures of the workshop eventually but this was pretty much the first large item I had to build as frankly my other "benches' were rubbish. Two worktops slapped on saw horses and rubbish piled underneath. Something like this.
So as I had just purchased my favourite tool and something on my wish list, a table saw, I wanted to incorporate a work bench , table saw and outfield table. It had to be cheap using basic available timber, be constructed really basic, have storage, mobile but also be flexible to clamp stuff onto it. So saw some ideas on youtube and various websites and drew up some basic plans which changed along the way. Just using plywood, CLS timber and my limited tools it was quite a fun build. My workshop is tiny, only 10x 8ft so I am limited on space !
First up rough dimension the wood
Then start building it. As I said very basic, pocket hole where needed and mostly butt joints.
Now I had the main structure, I needed to get the height of the table saw so it was just above the outfield table but also find a way to stop the table saw from sliding. So using my ham fisted attempt at free routing (which was pretty bad) I added some recesses for the feet. This kept it stable but got the perfect height.
Then added in full length drawer slides for the two front drawers , gave it all a couple of coats of protection , put the castors on and middle shelf. Then positioned the table saw at last and built the side expansion table for wide sheet goods.
This is a fold up table on brackets which gives me access to the battery ( flex volt saw) and also provides the extra space for handling wider timber sheets.
Kept it like that for a few weeks but had to tweak it . Always wanted some form of hold down system so added in some t-track ( god that stuff is expensive ) , a cheap vice and my handy measure holder which also has a pencil sharpener in it
All in all does the job , fits in the space and gets used and abused
Hope you like
Hope you like
