paulm
IG paulm_outdoors
Me too Roger, love that elm Rob, keep the pics coming....
Cheers, Paul![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers, Paul
woodbloke":1ho8ts6x said:The actual burr is 2mm thick and has been glued in the AirPress to the wide cherry rail which is itself 18mm thick...so the elm's going nowhereOPJ":1ho8ts6x said:Love the look of those panels, Rob. I've heard elm can have a mind of it's own at times - I hope those burr panels remain flat for you! :wink:- Rob
frugal":1tfys5z9 said:Wow, I am impressed that you managed to cut those burr panels at that size down to just 2mm without the whole thing falling apart. I have a hard enough time cutting pieces that are only 3" high when I cut veneers.
woodbloke":1sg0p9rn said:The actual burr is 2mm thick and has been glued in the AirPress to the wide cherry rail which is itself 18mm thick...so the elm's going nowhere- Rob
I hope the following pic shows the wide rail in a bit more detail:PaulO":240wea8f said:Can you explain how the ground work for the burr (18mm cherry rail) is joined to the legs / rails ? Does it float between the two rails? How is it allowed to contract without a gap opening around the ebony banding? It looks as though expansion would be applying considerable force to the legs as the combination of the burr and banding would constrain any float?
You mention 6mm ply loose tongues in the text, but I can't see them in the photo.
woodbloke":2f3w2jx6 said:Also any expansion of the cherry rail will be across the grain so the joint between the rail and leg ought not to open - Rob
PaulO":2gj4g1xu said:Ah, OK. So any contraction in the rail will open up the mitre with the legs? I think I might have applied the burr to an MDF substrate lipped with cherry for the mitre/exposed faces. That way you are also avoiding strain on the veneer from expansion/contraction. I presume the back of the panel receives the same burr veneer to keep it balanced?
I guess if the cherry has been dried over a sufficiently long period, and is at centrally heated house RH it shouldn't be a problem.
