R1chard
I have a cement mixer which suddenly went wrong. There was no leak to earth or overload trip.
It doesn’t rotate normally and then if it’s given a bit of help it struggles and turns in small slow jerky movements....
I have tried to replace the capacitor with a similar one, to no avail. This is the extent of my knowledge and edge of my comfort zone.
I have dissembled the motor and accessed the windings. I believe this is an induction motor (no rotor coil or brushes) and tested the wires emerging from the coil without any continuity error across the two white capacitor wires nor across the three other wires but I’m flying blind.
Visual inspection of the windings does show a little “scorching” and the resin is a little brittle but no more than I would expect on an older motor.
Any ideas?
Any ideas?
