lastminute
..anyone bought one of these router bit sets?... the ones that sell approx. 35 pieces for £35/£45
..works out about £1 per cutter?
..any good?
..any good?
Yes, with "sets" of router cutters (from any maker) at best you'll probably only ever use a third of them. It's much better to buy as needed and from a good maker (I mainly use Wealden). Still, having a cheopo set as well can occasionally get you out of trouble.nathandavies":31y4fh4b said:It would look pretty having all those bits, but you'd probably only ever use 3 or 4 of them. buy good quality of what you need. or as roger has said above buy them and you'll have them for when you get stuck. I suppose if you just want to try stuff out you could get them but you would quite quickly be replacing them with better quality.
Nathan
Spindle":3jt8fro1 said:Hi
I have a slightly different take on this - I'd buy a cheap set, (in fact mine is a Trend set of about 12 1/4" bits which were a give away with a magazine subscription). As said above - when new they are perfectly serviceable and as they wear I replace them with 'quality' items. This gives me the best of both worlds - I have a basic starter range of bits for very little outlay which in use, guide me to purchase better quality bits dependant on frequency of use.
Regards Mick
