ali27":psvwux74 said:
Matthew can you post some pictures of the planes on the forum?
Ali
Here's a handful, I only had about an hour so I had to concentrate on capturing the shots for the website, I'll try and get some more dismantled shots and closeups etc done in the next day or two.
The only way to remove the blade from the rebating block - you need to remove the brass screw that the cap engages on.
The only 'internals' shot I have so far, nice casting quality on the steel and bronze components and general fit and finish is excellent. The black mark on the frog is a low spot on the casting but there is plenty of neatly machined contact area for the iron to bed on.
The only shot I have of the spokeshave so far, a very comfortably balanced tool though.
Front threequarter of the No. 5, again good castings and machining, the only unexpected thing I'm not so keen on is the mahogany finish on the handles which will scratch and show the pale grasstree wood underneath - if it were me I'd sand it off and refinish them.
There might be the odd tweak required - squeezing up the arms on the Y lever so that they engage positively with the adjuster knob, (less than half a turn of play on all the ones I've looked at so far), polishing out the odd scratch on the lever cap etc but it's all two minute stuff. The big jobs that are a real pain to correct like an acceptably flat sole and a properly heat treated iron are all as they should be.
