I’m selling this lathe on behalf of the family of a past member of our woodturning club, with proceeds to be split between our club and the local hospice.
It has been well used, with a good deal of dried finishes on the paintwork, but it works as it should and has been fitted with new bearings and a new drive belt.
Sliding and rotating headstock.
Headstock, toolrest and tailstock all have cam-locking levers for adjustment.
A 3ph inverter controls speed and ensures the same power output even at low speeds.
A (TEMPERAMENTAL) digital display gives speed reading on both low and high speed ranges.
Reverse direction selector, 36 position indexing, hollow headstock and tailstock for long hole boring and a handle for manual rotation of the spindle.
Floorstand with four adjustable rubber feet and brackets for a storage shelf.
With four pronged drive centre, revolving tail centre, push button spindle lock, centre knock out bar, floorstand, 355mm toolrest, bowl-turning toolrest, 150mm diameter faceplate, screw chuck, and an outrigger attachment for bowl turning up to 810mm (32″) diameter.
Fitted with new bearings and belts - receipts can be seen.
I'm looking for £275 o.n.o.
If you want to see the lathe (Northampton - easy access), let me know by PM and we'll sort out time and date.
Duncan
Distance between centres | 1060mm |
Max diameter over bed | 400mm |
Max diameter over outrigger | 810mm |
Motor (Induction) | 1100W, 240V |
Speed ranges | 2(200 – 1600rpm, 200 – 3200rpm) |
Spindle thread size | M33 x 3.5 |
Spindle tapers | 2MT |
Headstock hollow centre diameter | 15mm |
Tailstock hollow centre diameter | 10mm |
Toolrest width | 355mm |
Faceplate diameter | 152mm |
Headstock rotation | 360 (pre sets at 45, 90, 135, 180, 270) |
Spindle centre to floor | 1130mm |
Dimensions (WxDxH) | 1790mm x 440mm x 1170mm |
Weight | 180kg |
Rating | Trade |
Duncan
