gregmcateer
He's got another one! Mark is a pro, who teaches and demo's the magma lathesso what will u replace it with I ask.....?
You can become a Supporting Member or just click here to donate.
At the risk of being a party pooper, it appears to be a private sale of a used machine offered at almost the same price as buying a brand new one with warranty direct from magma and paying the import duties. Sorry !Don't get me wrong - this is a REALLY great lathe
I agree, someone should grab this - it's not cheap, but a lifetime investment ( as is a good Wadkin ! )
Yes this is a private sale of a lathe that has only been used a few times, namely demonstrating at the European Show and a few times at Classic Hand Tools.At the risk of being a party pooper, it appears to be a private sale of a used machine offered at almost the same price as buying a brand new one with warranty direct from magma and paying the import duties. Sorry !
All the Titan lathes are built to a very high specification as you would expect with them being designed by a German woodturner/engineer, Markus - for example the bearing on a 315 or 400 will operate happily at speeds up to 7000 rpm ...lathe only goes up to 3000 rpm and carry 2 tons; rather than the cheaper adjustable locking handles genuine kip handles are used; the headstock spindle is 60mm diameter; bearing placement etcWith Mark's explanation, I agree that I wasn't comparing like with like. I simply referenced the manufacturer's website for prices of the current models which are the G series. I noticed that a simple 315 designation wasn't listed so couldn't determine the difference.
Magma's marketing has In the past made a virtue of their choice to fabricate the lathes from alloy steel rather than use cast iron. If the current 315G lathe has moved towards incorporation of castings to reduce costs then Mark has been missing a trick in his description of his lathe. Sometimes the older versions of a machine are built to higher standards than the current products and rightly become sought after.
You're going to need a bigger box........I have a Magma Titan 315G as well which I'm taking with me.![]()
