Charity Shop finds.
The_Yellow_Ardvark
22 May 2020
SW UK
Tidy small vice.
A rusty plane.
A bubble stick.
A set of cooking pots.
£10.
The cooking pots were probably for camping; easier to fit into the boot, along with tent, blankets/sleeping bags, etc., than individual pots.
I'll be interested to see that little plane when you clean it up; does it use a razor-type blade?
And that brass-bound level is lovely. Is it accurate?
The pots all nestle into one.
The plane is going to Men In Sheds. When it is restored I will post it it here, you will get first refusal.
The bubble stick is spot on.
It's a 'Spirit Level' !
Why I queered 'having a laugh' ?? when I started out as a lad the old joiner I talked two had one just like it and he too called it a "bubble stick" he also had a small spirit level with a pocket clip on he never went anywhere without it, I inherited them both when he passed, along with all his tools.
Most of the hand tools are Ebony.
Sorry for hijacking the thread just had to ask why.
I have two bubble sticks though I haven't heard them called that before. The 8" one I bought in my youff; the 6" I inherited from my father. I still use them occasionally though they are difficult if you can't look at them from above. They look just like the one in the first set of photos.
Its a stanly rb something 8 or 10 o forget. It uses disposable special blades. You got different cambers and stuff. Or you could get a kit to tae a more traditional t shaped rebate blade. It came with a parrallel guide.
Very much a diyer aimed tool but mine is hefty and often think with a proper blade its probably a pretty useful step up from a fillister plane. But effort... So its still in the box 🤣
Today's car boot bargains. £2 for the small glue pot and spokeshave. £4 for the imperial hole punch set. They are now soaking in vinegar.
The Badger airbrush was a previous bargain a month back. The whole boxed kit was £15 knocked down from £20.
Do you soak it in vinegar straight from the container or do you also add something to it?
How long did the tools soak for? Good result.
I soak them in vinegar and baking soda. I left them in there for around two hours. Most of the rust will then wipe off then I wash them under a tap. I use a wire wheel then a medium grit fibre wheel on one of my bench grinders. The punches can be chucked up to be sharpened with a diamond file on the lathe. Finished off with my manky, oily rag.
Wow that's brilliant if that's the result simply after soaking in vinegar and I guess a little wire brushing. I'll have to give it a go.
I soak them in vinegar and baking soda. I left them in there for around two hours. Most of the rust will then wipe off then I wash them under a tap. I use a wire wheel and then a medium grit fibre wheel on one of my bench grinders. The punches can be chucked up to be sharpened with a diamond file on the lathe. Finished off with my manky, oily rag. The glue pot is finished with linseed oil,
