al3ph
Hi, I've noticed my new bandsaw is actually two speed, not that the documentation mentions this at all.
Does anyone know how you actually do this, there doesn't appear to be enough slack on the belt to allow it to be moved, is it a case of removing the lower wheel ?
Also is there meant to be some left/right movement of the blade while in operation, I'm guessing the tire on the upper wheel isn't perfectly round, at least that's the only reason I can thing of for this behaviour.
cheers!
cheers!
