Can anyone explain if they know how to change the drive belt on a Lurem 260C I combi saw 3 phase 3 motors, as I can see I may need to remove saw moter?, thanks if anyone can help ,the lurem machine is from the 80s and French no longer made
Thanks for any help, it's done I found yo have to remove two bolts with a 13mm spanner on the left hand side of were the moter is fixed were you have the leave to raise and lower the saw, I will try and up loaded photos . Let you know in a few weeks when belts fitted and any problems. Other wise it was not possible to remove belt untill moter had been removed, but was easy, see how it all goes back togetherCan anyone explain if they know how to change the drive belt on a Lurem 260C I combi saw 3 phase 3 motors, as I can see I may need to remove saw moter?, thanks if anyone can help ,the lurem machine is from the 80s and French no longer made
