I suspect that this motor body will be designed into the structure of the saw and direct drive on the saw? Ie no belts/pulleys - please say if it is a standrd motor as you could possibly swap it for a single phase motor.
If it is a special then you need to proceed with great caution not to damage it beyond repair. the choices are to find the star point and convert to delta - this is a skilled job then you can run from an inverter. Otherwise leave it well alone and instead puchase a converter that will provide 415v 3 phase from your 240v single phase supply. this is then just a wiring job with minimal risk.
Ok As it is a belt driven machine I'd just put a 3 hp dual capacitor start and run motor on it for the cheapest, easiest solution.
First thing is that I would not darken the doors of machine mart. They have/had a poor reputation for handling warranty issues. Might just be my predjudice but there are better places to go where you can get expert back up.
We need to know much more about your motor. The photo you have already posted claiming to be the motor rating plate is really the machine plate as it mentions different speeds. that are higher than any induction motor can achieve on 50hz mains.
We need the actual parameters of the motor itself. Hopefully it is a metric sized motor as they are more available. for size and mounting styles see the appendices in my motor paper here https://drive.google.com/file/d/0B_GZrXNsNxTlQzd6aldlQjJtUDQ/view?usp=sharing
You need to find if it is a 2 pole (2850 rpm) or a 4 pole (1425 rpm) and get the same speed of motor. Is it face, flange or foot mounted?
Face mount has the bolt holes on a circle smaller than the motor body, flange mount has the bolt holes on a circle larger than the motor body and foot mount has feet with bolt holes.
A general photo of the motor on the machine with the belts, pulleys and mountings will help set the context for us. Don't forget you have the thing in front of you- we have never seen it yet.
Can I suggest that you remove the motor and post photos of it. This might expose a plate with the infomation we need; otherwise some more measurements will be needed.
That is your homework for now!
Bob
Probably the best place for it...we have taken the saw motor to a motor specialist
None of those options are going to come in at around £100 though.Probably the best place for it...
Is he going for star point extraction, or a step-up inverter?
I would take advice from the specialist about inverter drives. For a start, you generally spec them according to full load amps, not kW/hp, and, especially if you’re going for the cheaper end of the market, it’s better to overspec the inverter somewhat.
No, although you can get a 3hp 240V inverter for around £90, and someone on here found a step-up type for similar money. Undoubtedly low quality.None of those options are going to come in at around £100 though.
It should just be a straightforward download for the link but I have attached a copy to this postHello Bob I've tride to read your motor paper but I ca'nt get it , I have an iMac does that make a difference . All the Best Des
