Hi all
I'm gonna be building a chair soon using dominos for the joints. I'm in the process of sorting out which domino sizes to use where and have a query I'd really appreciate some advice on.
This image shows where the slats join the lower back rail. YOU MAY NEED TO CLICK ON IMAGE TO MAKE IT BIGGER.
The slats are 24mm wide by 16mm thick. The only domino really which can be used to join the slats to this rail and the crest rail is the smallest domino which is 4mm thick by 17mm wide by 20mm long. This would mean 10mm of domino in the slat and the other 10mm in the rail. It would also mean that there would only be 3.5mm of timber around the curved sides of the domino (24 minus 17 = 7 divide by 2 gives 3.5).
Do you guys think this joint will be strong enough? If not what are my other options to still use the domino for this joint?
Best regards, Andrew
