AJB Temple":1kzysbem said:
I always struggle with this. I have a bunch of Stihl tools (chainsaws, pruner, blower, hedge trimmers, streamer) but I only use them at home in etc garden and paddocks. So it is not continuos use and it can be a few weeks between each use of, say, the chainsaw. I find that any fuel mix I make up goes off really quickly and the Stihl user guides say do not keep fuel mix for longer than 30 days. Once it is a bit old, or if I leave fuel in the tank, the tool is often hard to start.
Now I use a 1 litre Stihl mixer bottle that has a 50:1 measure tank at the top and as far as possible run the tool dry on each use. This is pretty easy to use to get the mix spot on and I find the small engines very sensitive to being over oiled. I don't use enough chain saw oil to worry about the cost of that, so I just buy 5 litre bottles of chainsaw oil from the garden machinery supplier. Chainsaw seems to go through chain oil at about the same rate as fuel (i.e. when fuel tank is empty, chain oil tank needs filling as well). I tried biodegradable oil in my last saw and it was awful for low temperature winter use: went claggy.
I have wondered about the pre-mixed long life fuels. My local place only sells the Stihl pre-mix as far as I know, and it is incredibly expensive: at least 5 times the cost of buying my own fuel and oil and mixing it. Is it really much better? My main issue is I want the tools to start easily. I am a bit of an ignoramus in this area.
My mate repairs and sells Stihl products, and he says you must use the following sequence to start a stihl engine.
Press the fuel bulb (if fitted) until it is full, then choke on and ignition switched on.
Pull the starter cord until it fires, (usually the 3rd pull, I find) return the choke to OFF, then pull the starter cord again,
motor starts and "blip" the throttle and warm the engine, any other starter method will flood the engine.
I've got a stihl chainsaw, blower, strimmer and hedge trimmer, all start easily by the above method.
Cheap chainsaw oil is ok but the genuine stuff is best and does, he tells me, help prevent guide bar, chain, and bore wear.
After all why buy the better quality machinery and try and save running costs, It's a better machine and will last ages
The professionals and arborists that come to him all use the recommended oils, etc so it must mean something.
Regards Rodders
