Misterdog
Woah your numbers are way off there. A modern condensing boiler can be over 90% efficient, some almost 99%.
Only when in condensing mode though.
When they are not they are only 60/70 %.
You have no option, condensing mode is dependant on the system.
Something to do with the temperature differential on the flow and return pipes.
Just looked. my boiler has been on for 6045 hours of which only 57% was in condensing mode.
https://www.google.com/search?q=how...9i57j69i64.18440j0j7&sourceid=chrome&ie=UTF-8
Strangely when selling you a new boiler they only focus on the 90% +
figure.
Indeed. There is no 'condensing setting' the boiler can only condense when certain conditions allow it to do so.
Though turning up the boiler stat reduces the time in condensing mode
(system dependant). I fitted weather compensation control which alters the stat automatically depending on the outside temperature.
I can tell how cold it is outside as the radiators get hotter.
The boiler has paid for itself in gas savings over 3 years, though I installed most of it myself.
It's an Ideal boiler which is superbly engineered, it has a processor and screen which gives me the information about burner time and efficiency level.
Far better than the Worcester Bosch I had before.
Gone for the majority, but not everyone.To get a condensing boiler to run in condensing mode the return temperature has to be low, around 55° C and to achieve this you must correctly size the radiators. Also they can be more efficient in newer instalations where full zoning has been applied through design, so all rooms can achieve the required temperature as they each control the boiler via a stat & zone valve. Gone are the days where there was just a stat and often the boiler just cycled.
Gas consumption is the same as in 2019 when the boiler was performing as expected.do you know for sure that it's burning the same amount of gas or oil (whatever it normally would) when it's on? If it's oil, is there a chance that an injector is clogged?
My boiler Crane CavalialWoah your numbers are way off there. A modern condensing boiler can be over 90% efficient, some almost 99%.
An old boiler from the 60's would have been lucky to be 50% efficient when new, dread to think how bad it is now.
The boiler specification is input 80,000btu/h, output 60,000 btu/h which I took to equate to 75% efficient.Woah your numbers are way off there. A modern condensing boiler can be over 90% efficient, some almost 99%.
I'd be interested to know the actual figures in relation to expenditure for modernising, presuming their condemned boiler was very old.It does sound as if the system is clogged, which isn't surprising given its age. A word of warning that a professional flush is very expensive (I seem to recall paying £400 in 2006). Given the potential energy cost savings you might want to think hard about a replacement boiler, but investing in a visit and advice from a heating engineer would be wise. Our neighbour started to have problems with their old boiler and the engineer basically condemned it. They had a new energy efficient model fitted together with TRVs and halved their fuel cost in the first winter. They live in a 300 year old cottage.
This article might be helpful
Boiler Grants: Can I Get A Free Boiler? - Which?
It could now be the oldest working boiler in the U.K.My boiler Crane Cavalial
