space.dandy,
Apologies, but do you have answers to the following:
1. When the tank has been heated, is the pipe out from the tank really hot - can you hold you hand on it, or does the heat force you to remove it?
2. Do you KNOW for CERTAIN that you're running out of hot water, or is it that the hot supply goes cold?
I've had roughly similar hot water issues, and NOT saying yours is the same but I've traced mine to a faulty shower control. I have separate temp & flow controls on the shower. Leaving the temp control in a particular position was (and still does!) allow the cold supply to flow into the hot feed, so all hot taps then flow with warm or cold water (rather than piping hot). Moving the control to a different position blocks off the cold supply or equalises the pressures between hot and cold, and all is well. The cause of the behaviour is one of the non-return valves (designed to prevent this very occurence) within the shower control isn't working properly, so need descaling or replacing. A common issue I'm informed.
If this description is in any way helpful, so be it, otherwise....I'll go back in my shell.
