stuartpaul
We've had a false chimney breast installed together with a gas fire. I'm going to fit coving to make it fit in better with the rest of the room and need to 'mitre' the new corners to give a seamless feel.
Is it best to try and 'scribe' the new coving to the old (doable I think with a bit of filler after to make good) or cut the old coving to make a new mitre? This is going to be difficult but not impossible. Scribing will be a bit hit and miss as you can't do the old 45 degree trick to cut the mating surface.
I'm not a massive fan of coving but I'm not going to rip out all the old stuff to make it look the same. And yes, it does need doing. Without the coving it looks unfinished and sticks out like a sore thumb.
