fatmarley
Do you think a coat or two of Rustins clear MDF sealer on the joints would be good idea before using the Morrells primer/sealer?
If Morrells specify that their sealer goes on the MDF first then no (there's also the issue of compatibility - mixing products from different systems can cause problems as one can react with another).fatmarley":3tgjsj9c said:Do you think a coat or two of Rustins clear MDF sealer on the joints would be good idea before using the Morrells primer/sealer?
fatmarley":1dm210df said:Had a look at the paint doctor website and he said the best way of sealing an MDF edge is to fill it and then sand. I wonder if some wet rot wood hardener would stop the edge from fluffing up?
