samhay
It seems I may have worn out the cap iron on my old Record 05 1/2.
I recently purchased a new iron for this plane as the old (probably original one) was getting a bit short. Setting the new one up - which is from Ray Iles, and is very nice - it would appear the cap iron is too short to work properly. The new iron doesn't yet have any camber, so I had a play setting the cap iron close to the edge. However, the hole in the cap iron fouls on the frog screw well before I can extend the iron far enough to protrude from the mouth of the plane.
To get the plane working, I have had to set the cap iron back a good 1/4" from the edge of the plane iron. This feels a little gauche, even for a jack plane. And yes, I will grind some camber into this at some point, but it would be nice to have some wiggle room to allow the cap iron to have some function.
It would be nice to fettle the original cap iron to make it work, but I'm not sure there is much I can do to 'fix' it, is there?
Assuming the answer is no, does anyone have any recommendations for a new (or new to me) 2 1/4" cap iron to suit an old 05 1/2 plane?
Thanks.
Edit.
A picture might help. It's fouling where the red arrow indicates.
Thanks.
Edit.
