toolsntat
Yep, I collect tools and tat
If you're quick Chris you could be the proud owner of this classic craft
A tad compact but....
You have PM
Cheers Andy
You have PM
Cheers Andy
But what do you do with “contents” whilst the composting takes place?Have you thought about having a composting toilet?
They take a bit of getting used to [we made some smelly mistakes early on]. But once you've got into the rhythm, they're surprisingly easy to run. And they solve the "creeping across ice-bound gangways to the toilet block in winter" problem.
When I looked at one I had set a length limit of I believe 57ft or thereabouts so that every UK canal would have been accessable, some up north cannot take 60 footers due to the shorter locks. It had an Izuzu diesel and a generator that was so well fitted that it was nothing more than a slight hum when running, had all mod cons such as a washing machine and fridge/freezer but you would need to get used to long thin living, it was built in Poland and to high standards, I do remember the welding was very good.To live on, make sure you get one with decent electrics - lots of solar, good charging, lithium batteries if you can afford them etc.
Go on tell us what it is!!If you're quick Chris you could be the proud owner of this classic craft
You have PM
Cheers AndyView attachment 113942View attachment 113943View attachment 113944View attachment 113945
Go
The boat we hired had an Izuzu engine ran as sweet as a nut.
Cheers James
B.O.A.T>
Break Open Another Thousand
My brotherinlaw lives on a boat, nice guy barking mad, I think that may be per-requisite, on both counts.
Store them in bags on the roofBut what do you do with “contents” whilst the composting takes place?
Bod
Hope you got good bags!Store them in bags on the roof
The Canal & River Trust has recently banned them from the canal rubbish bins because too many were arriving in, er, pre compost state. The rubbish bins are sorted manually to separate recycling at the Biffa depots. Yuk!
Yes length is limited on northern canals but width is the main restriction - there’s no way from south to north in a widebeam except via The Wash. And, yes, the Polish built Aqualines were v good - steelwork in Gdańsk shipyard and woodwork using redundant machinery from the UK.When I looked at one I had set a length limit of I believe 57ft or thereabouts so that every UK canal would have been accessable, some up north cannot take 60 footers due to the shorter locks. It had an Izuzu diesel and a generator that was so well fitted that it was nothing more than a slight hum when running, had all mod cons such as a washing machine and fridge/freezer but you would need to get used to long thin living, it was built in Poland and to high standards, I do remember the welding was very good.
B.O.A.T>
The other definition of boat is "A hole in the water surrounded by wood into which you throw money"It would seem there’s a lot of truth in that, I've worked for several folks with boats the one chap had an ocean going craft the ownership of which he described as being akin to standing at the waters edge continually throwing £50 notes into the water I said he must be mad, didn’t answer
The only poo on our boat roof comes from pigeons. I’m far from convinced about composting toilets.Hope you got good bags!
Bod
As others say: for solids, store them in [closed] buckets the roof. Need to add some bulk material [paper, sawdust etc.] each time you poo. Then, in a couple of months, it breaks down into dryish compost, that doesn't smell. For liquids, use any flush toilet. Overall, you'll be surprised by how LITTLE it all comes to. Two people, living abroad full-time for five months, generated one and a half 10 litre paint tubs of compost.But what do you do with “contents” whilst the composting takes place?
Bod
