novocaine
you can get precision by hand too you know, watch makers managed it anyway.
AES":qmkle7wh said:As part of my apprenticeship I was taught to be able to file flat and square to a tolerance of plus/minus one thou (Imperial). I won't say it's easy, but once learnt ("just" a lot of practice basically) it's not forgotten.
And I'm sure that confidence applies to anyone else who served a similar apprenticeship to mine.
AES
AES":2uf4re83 said:Well I guess you COULD get away without a lathe, but a pillar drill would, IMO, be an absolute necessity. And having no lathe would make life a LOT harder (but not impossible, please note).
So the lathe makes life a helluva lot easier, not only because (once set up correctly) it will cut holes and make pillars, axles, threads, etc, which are absolutely concentric with the centre axis of the lathe (or eccentric to the axis, come to that!), but by it's very nature, it also allows the production of a straight line (e.g. a cut) which is absolutely parallel to (or perpendicular to) the centre axis of the lathe. And with the right attachment (e.g. a vertical slide) it's also possible to accurately set up angles other than 90 and 0/180 degrees.
So buy yourself a lathe mate (and while you're at it, a vertical mill too)! But also, be prepared for A) an outlay on tooling, etc, which at least equals the initial cost of the machine itself, plus B) a long (but fascinating) learning curve.
You're quite right, it IS an absolutely absorbing hobby/pass time/obsession, whatever you want to call it.![]()
AES
