Ring":1au1h3z8 said:More to the point when are you doing a production run
Many thanks.woodpig":fsjrpeba said:Quick Sketch.
Thanks. I guess you make the sleeves yourself too?woodpig":1rgwy1cu said:The 22 x 8 x 7 bearings used are commonly available and cheap to buy. Using sleeves and M5 bolts into the 10mm adjusters is pretty similar to what others are doing and made sense to me. Yes the grooves are just to grip the ends of the adjusters. The bearings are designed to take the load in the way I (and others like Carter) have used them. Doing it any other way means they're sure to wear out quicker. My bandsaw is now quieter with this setup than it was with the record "disc" bearings.
Some manufacturers take the easy way out and put the thrust (back bearing) the "wrong" way round. This is fine if it's easier for you to make but it may be a little noiser and wear out a bit quicker but it's only one bearing and as said they're cheap enough to buy.
See https://www.youtube.com/watch?list=PLF6 ... _bUCTCNUmowoodpig":2vm0wzrx said:Yes I made all the parts.
I don't see how scraping the blade down the side of a bearing can be quieter? Here is another bearing guide made the "right" way like the Carter.
http://youtu.be/seZ2IJfylec
I guess his table saw experiment was just a way of trying to test out why there was such a large difference in volume level on the bandsaw between the two arrangements.woodpig":29v4j13h said:I'm not sure what running a bearing over a cast iron saw table by hand proves as only the fine edge of the blade is in contact with the bearing. I have to admit he is quite amusing at times though. He refused to get into discussion with another issue I found so he is quite single minded.
I'm happy with the Carter design so I'm sticking with it even though it would have been much easier to put the bearing against its normal rotation. I'm sure either design will work for you though so just pick the easiest for you to make?
Makes you wonder though doesn't it that the cheapest and easiest way of doing it would be with wooden blocks and yet no manufacturers use this method. Maybe it's the fire hazard?!
I guess it's part of the cost efficiencies needed to make something at a price you can sell (and make a profit) but they do look like cr*p compared to the guide block you made! I guess there's probably a few more hours in yours than their's - which I suspect would probably still be true even for a full CNC mill.woodpig":3jjcf7ln said:I looked at my own link again and noticed they sell on eBay.
http://www.ebay.co.uk/itm/Delta-10-Band ... SwA4dWH8Ds
Not sure if they make them to fit record bandsaws but the price is good.
Indeed. Functional, but certainly not beautiful.woodpig":3mqcnsa3 said:Those welded ones may not look so good but I'm sure they'll work just fine and the price is right.
I do have some bearings in a drawer somewhere so I should try it.woodpig":3mqcnsa3 said:I made a tool some time back called a "nudger" by some folks. It's the rod Near the rear of this picture with a bearing on it the same as the ones on my guide. It's used for aligning stuff on my metal lathe.
As an experiment I moved the top guide back on my bandsaw and pressed first the periphery and then the edge of the bearing of the nudger against the back of the blade. There was very little difference in the amount of noise produced. As the face of the bearing is moving at different speeds thought relative to the bandsaw blade it did produce some sparks, not good on a machine that produces lots of sawdust. Someone on here is visiting me in a couple of weeks so I'll see what they make of the difference!
I suspect the bandsaw makes more noise actually cutting the wood than the bearings make so maybe we need quieter wood! :lol:
novocaine":26dpwge3 said:whilst a milling machine would make it so much easier to do, you could do similar with hand tools (and a pillar drill), it isn't going to be fun, but it's doable. you'd have to change the design of the shafts to be more generic and there would be lots and lots and lots of filing to do. reckon what took the right honourable Mr woodpig to do in a few days would take you a good week if not more.
on the plus side, you'd have arms of steel by the end of it.
