Steve Maskery
Evening all,
I know that this is a long shot but here goes.
My car has washers for the headlights. Not the wipers, just the squirty bits. One of them has gone AWOL, so I rang up for a replacement.
How much? £22, Sir.
OK, could be worse.
It was. That is just for the jet. I also need the plastic cap which covers it, £47 +VAT, and it only comes primed, so I'll have to have it sprayed. That means mixing a batch of paint and setting up a gun. It's a metallic finish, so needs a topcoat too. I reckon all in all I'll be lucky to get much change out of a couple of hundred quid. It's not going to happen.
So I'm thinking I'd be better off removing the other one to match, and bunging up the 36mm hole in the bumper with a closed grommet or cap. At least they would both be the same.
I can get closed grommets locally, in Maxipcks, but they don't seem to go up to 36mm. Does anyone here work in grommets? I need two. As samples, you might say
Or any other ideas for making an odd car look balanced. I might consider turning a cap out of black phenolic, if I can get a decent finish on it. The car is red, I don't expect to get Renault Flame Red grommets though!
Any help or ideas gratefully received.
Steve
How much? £22, Sir.
OK, could be worse.
Steve
