Hello,
Can someone explain me the proper use of knife wall method? It is described in Robert Wearing's book and also popularized by Paul Sellers and others.
Basically, I score a line around the board and chisel out a half V groove. Then I register my saw against the wall which should help me cut straight.
At the same time, I cannot register the saw against the wall, as the set of the saw would cut past the wall, so I have to cut just arbitrary distance away from the knife wall that I deem appropriate as not to disturb the wall with the set.
Or I can tilt the saw to cut a bit away from plumb to the outside.
So why bother with the knife wall, if I cannot register the saw plate against it?
Thank you.
Thank you.
