That changes things!
I don't know the answer - I think only a maker of reproduction Celtic harps would have any direct knowledge. However, the following thoughts might be helpful:
1. It depends on what species of poplar you have. European White Poplar (Populus alba) is related to Willow but a different species. It's quite a bit softer and weaker, which could be a problem. Tulip poplar (Liriodendron tulipifera) from the US is what's commonly sold as poplar. It's unrelated to willow, but has quite similar properties - a little softer but perhaps a bit stronger in terms of elasticity, which would be useful for a soundbox. It's about 12% denser on average than Willow, so you'd either want to carve the soundboard a little thinner or find a particularly light piece of Tulip poplar. That apart, it should work in quite a similar way.
2. In terms of musicality, most non-dense wood species can make decent musical instruments. I've made ukuleles from mahogany, sapele, koa, oak, spruce, cedar, among others. I've not come across a poplar instrument, but that's probably because the wood is dull-looking and non-traditional. I'm sure tulip poplar can make music. Instrument makers tend to choose boards or billets by listening to how they ring when held at once corner and rapped with a knuckle, chisel handle, whatever. Some boards ring, some go thunk. Pick one that rings.
3. No idea how to carve the soundboard part - with luck you have plans or pictures to work from. As the strings run along the grain, not across (modern reproductions run the soundboard grain at 90 degrees to the string line for strength) I'm sure there must be some reinforcement internally. If I were making a harp using guesswork I'd run a strut along the string line, maybe 12 x 12 mm, to reinforce the string anchor points and to strengthen the board against splitting. When stringing up I'd go to partial tension and then assess the bulge of the soundboard, adding 90 degree bracing if needed (6 x 12, glueing the 6mm dimension to the board) and re-checking.
4. Shrinkage with humidity change is big in willow, and a little more in tulip poplar, so I'd want my billet to have vertical grain (||||||||||||) for the soundboard part - shrinkage across vertical grain is half that of shrinkage radially! The billet should move as a whole, reducing the risk of cracking, but you don't want it to distort. Also, cross-grain stiffness (resisting the strings) is highest with vertical grain.
I think you just have to try this and see how it works. Good luck!
