Deadeye
Specifically, there's a good value 10mm upcut carbide spiral that I'd like to use (10mm shank and diameter). Any reason not to?
Any reason not to?
LolYou will have to learn to speak G-code.
Reasons not to would be if your spindle is very underpowered, and/or the CNC machine itself is too light/flimsy to take the loads of using a 10mm diameter bit. Finally, upcut bits can tear out the top face on some materials (e.g. plywood). But other than that, if the speeds, feeds, and Depth of Cut is appropriate, it'll be good.Specifically, there's a good value 10mm upcut carbide spiral that I'd like to use (10mm shank and diameter). Any reason not to?
Thanks - it's going in a meaty router so I think should be okReasons not to would be if your spindle is very underpowered, and/or the CNC machine itself is too light/flimsy to take the loads of using a 10mm diameter bit. Finally, upcut bits can tear out the top face on some materials (e.g. plywood). But other than that, if the speeds, feeds, and Depth of Cut is appropriate, it'll be good.
You'll be fine then.Thanks - it's going in a meaty router so I think should be ok
