can any help me as to what this plane is used for and called
tobytools
12 Apr 2013
bournemouth
can anyone tell me what this is used for what its called, lovely little thing! ill need to make a wedge as i have no spares that shape but this i can do, what type of blade or iron would it take ext, any info would be great
thanks
TT
can any one make out the serrated makers mark, and does that make it 18c? and is there ant tricks to bring out the name more ie a sort of dye
    56.5 KB
    72.5 KB
    45.8 KB
    118.4 KB
    148.4 KB
    95 KB
It's a router plane. Like an 'old woman's tooth' but arranged lengthwise, more like an ordinary plane and therefore possibly easier to hold and use. So its purpose is to level the bottoms of housings (what Americans call dadoes) and grooves. Normally used with plough plane irons which have a standard width body to fit in the groove on the bed.
I can't make out the mark with the zigzag border and think Mr Cresser might have overstamped it
I don't know a way to make it clearer but do know that cleaning and polishing a plane can sometimes swell the fibres just enough to make a mark disappear!
Nice plane though and a surprisingly unusual pattern. I'll take a photo of my one later on.
Edit: here's mine - no maker's mark.
Thanks Andy, I thought I was some sort of open throat router plane, when I googled it I couldn't find anything.
Is your just a custom block, I like it Do you use it? And is it better or worse than a modern router. adjusting is probley annoying as you could tap it to hard.
I will get my magnifying glass out later and try and suss the name.
TT
Hi Toby
Google is tremendously useful but there are some subjects where you really need some specialist books.
The first one on anyone's list ought to be RA Salaman's Dictionary of Woodworking Tools. It's in print and widely available from places such as Classic Hand Tools or secondhandtools.co.uk It covers almost every ww tool you are likely to find and gives lots of readable background info.
I'm pretty sure that both our planes would have been professionally made.
As it happens I've not made anything with housings in since getting this plane so have not yet done a full comparative review!
This is an interesting topic.
I suppose that typically wooden OWT or Granny’s Tooth routers tend to support their irons close to the vertical and have a short stubby base for working across the board.
However, R A Salaman does show a selection of different routers in the Dictionary of Woodworking Tools.
One is converted from what appears to be a short coffin plane (fig 526 a), whilst there is an illustration of a plane (fig 526 e) just like yours, which he called a ‘home made example.’ As it has a long base, I'm tempted to think that it may have worked along the board, rather than across it; trenching a recess with the grain instead of across it.
Possibly it was cut down from another plane long ago. Who know? Jobbing joiners would have cut countless housings or trenches in the 18 / 19th centuries.
Some while back I had a large number of mortise and tenons to cut (by hand) and I wanted to ensure that the tenon cheeks were all the same depth and in the same horizontal plane as the face side.
I thought of trimming along the grain, using the face side as a bed, instead of across, using a shoulder pane, or paring chisel.
I experimented with conventional metal (Stanley / Record) routers but these don’t sit at all well on a long surface – they like to work across the grain and you can't turn the blade 90 degrees. The old Preston routers will do this very well indeed and can have their blades turned at right angles, but I had three different depths to cut and it would have meant continually altering the setting.
I solved the problem by utilising some redundant plough irons and making my own long router plane. It's a bit of a hybrid, but was very successful, so I made another. That meant that, in combination with the Preston, I could have three different depth settings throughout the job that remained the same.
I wrote about it with more detail in the blog here, if you are interested. The pictures explain the process better than I can here:
http://handmadeinwood.wordpress.com/201 ... an-outing/
I should add that I made a later post in the blog about how the long router was made:
http://handmadeinwood.wordpress.com/201 ... on-router/
It’s probable that the old joiners had two or three (possibly homemade or converted) router?
I found that it made a big difference to the way that I could turn out well fitting tenons consistently and quickly, and it's not far removed in concept from the original that started this thread.
All best from Wales
