Chrispy
Are you there Myfordman?
I need some advice wiring up a large motor, as per pictures it's 3 phase and has been star connected in the past.
My main concern is the best way of switching it, do you think a DOL 415v starter fitted with a 13.0>18.0 Amp overload be OK?
If it helps it's a rotary vane vacuum pump so apart from it's own momentum it won't be starting on load.
Thanks for your help.
