RogerS
I've been musing about the kitchen in particular electrics and Part P - first fix inspection.
Currently the walls are part-tiled exactly where you would expect to see wall-mounted sockets. I'm tempted to chisel them off and then get the wall reskimmed. In my experience that has always given the best end-result. But what about the electrics?
Pre-Part P I would most likely have chased out the wall for the cable runs, chased out for the wall sockets, installed the cables and then made good. Cabling for the appliance sockets would be in plastic conduit behind the floor units.
So - post Part-P - at what point do you get them in to inspect? After chasing and laying in the cables but before making good?
Also re making good, in my experience you never get a very good result trying to skim the plaster back over the cables in a seamless way to the rest of the wall. But perhaps that's just me
Is there a better way? use those pop-up mains sockets that come out of the worktop?
This time I intend to keep the kitchen on its' own ringmain with a separate grid switch.
Many thanks in advance
