- Joined
- 6 Jun 2011
- Messages
- 2,995
- Reaction score
- 911
sihollies":31dxtt0r said:Thanks again for all your advice.
I contacted Crispins and they informed me that they had no access to a paper that could back veneer, or the whereabouts as to where I could buy such a product.
I bought a couple of different gummed brown paper tape, but the adhesive wasnt strong enough to hold the veneers secure when peeling the masking tape off. ( I use masking tape to build/construct the parquetry sheet. )
I have however made a A3ish size press/clamp using 18mm MDF with several bolts around the edge This allows me to clamp a pre made parquetry sheet coated with a 1:4 PVA mix to a piece of brown parcel/wrapping paper.
I have had success on some small sheets, in that after I have glued the backed parquetry sheet to the ground work, I just dampened the brown paper with a sponge and it just peeled off.
However on larger sheets, I have found that the PVA doesn't dry, I assume, due to the lack of oxygen that is within th press/clamp.
Could you please advise of a adhesive that I could dilute that doesnt need oxygen to go off, that will alllow me to dampen it after setting to remove the backing paper.
Many thanks
Simon
I do not use the method you are trying but I have used Solvite wall paper paste on occasions in woodworking it might just be right for your application.
Cheers Peter
