Ike wrote
Please, I'm genuinely intrigued by the discussions about what planes to buy (or what not to buy as the case may be). Perhaps this could form another topic with the emphasis towards educating plane numpties like me.
First point Ike... owning one new Stanley doesn't qualify you as numpty; that's reserved for the likes of me... 3 Stanleys and a Record..
First up, the finish quality of the casting is borderline "fit for purpose" at best; check it out with a straight edge, you'll see what I mean. Secondly, as Alf pointed out, the quality of their blade steel is dubious; ideal stuff to teach you how to sharpen properly as you'll get plenty practice in a hurry.
For me, the worst aspects with the bench planes happened when I tried to close their mouths; moving the iron off the rearmost face of the throat meant that the iron had less support; it totally refused to cut. Even when set fine, it would catch, deflect rearward, digging-in in the process, rip massive chunks out the board before chattering through the rest of the stroke. Back the adjuster off 1/8th of a turn and it wouldn't cut at all. It struck me as pointless having an adjustable frog at all when that happens when you try to use it.
For me, the single worst aspect was when I was physically able to deflect the body of the #7 so far that the blade caught and dug into the bottom of a hollow (I'd only just started trying to straighten the board after planing cross grain with the jack), the tear out in the hollow had me stumped till I sat and figured out exactly what had to have happened. Bearing in mind, I'm no Geoff Capes, I found it utterly ridiculous.
I still use the Stanley #5, and will have to continue to do so until I can afford to relace it. With it tuned and flattened properly, frog set to have the back of the throat support the blade it's still a capable tool especially after my scrub plane's done the initial shaping of the board. But that wide open throat and bendy as hell blade means the days when I trusted it for fine work are long gone... As for a doorstop, try beating a #7 for size.
My story with their block planes was much the same. I bought a Stanley 220 (I think......no model # on the casting). After spending 4 hours tuning it, sharpening, flattening and honing the blade on 8000 grit, it managed to achieve doorstop status on after just the one board. It stayed together just long enough to chatter and bite chunks along the full length of the board edge, the chatter being bad enough to shake loose the quick release cap iron and let the thing literally fall apart in my hands. I'll spare the sob story of the Record 9 1/2 block plane; suffice to say that although it lasted longer, the result was the same. Thesedays it serves as a paperweight in the shop, doubling as a constant reminder NEVER to buy new Record again.
To my mind, any iron plane should conform to 5 main points.
1/ The casting should be stiff enough to resist flexing.
2/ The sole should be flat
3/ The sides should be square
4/ The iron should be both thick enough and hard enough to resist flexing in use
5/ All burrs and sharp edges created during the machining process should be removed prior to assembly / shipping.
These 5 points are, imho MINIMUM requirements to qualify as fit for purpose; there's a far longer list to define a GOOD plane. Having to spend 4-6 hours working on a NEW product bought in good faith from a manufacturer with a good reputation is utterly ridiculous.
I know there are aftermarket blades that will improve the planes, but it's my belief that, when the planes NEED an upgrade like that, it SHOULD be done by the manufacturer; if I attempted to pass off a half finished wiring loom as fit for purpose, I'd be fired. Nuff said...??
Ike, I hope this ramble hasn't put you off; there's a LOT of good manufacturers out there making first rate tools. If I were you, I'd have a good long look at the product ranges of Clifton, Lee Valley and Lie-Nielsen; you winna go far wrong with them. Granted, they're more expencive... their difference is... they're worth it.
