Bureau flap hinges
Jacob
What goes around comes around.
7 Jul 2010
Derbyshire
Any recommendations for a pair of brass bureau flap hinges?
That is a flap hinge with the countersinks on the flat side, not the barrel side, set in, so that all is flat when the lid is open.
"Counter flap" hinges I've looked at, look wrong with their two barrels. Bureau lid only has to turn through about 120º not the whole 180º
Think I have a pair in my stores if you can't find any, do you know what size across the knuckle?
Peter
Thanks for that Peter. Got to cut them in so any size might do.
It's a repair/rework on an old one which wasn't put together well and the original pivot hinges have broken out beyond repair. The design has two pull-out stays which someone forget to pull out and the lid dropped right down and broke away. Just bad design!
I replaced some bureau hinges for a client a few years back, and my invoice describes them as 'back flap hinges'. A google of this finds some likely suspects.
